Error solution in hfss
chandra2027
Newbie level 5
TEMP LOCATION :AJMER, PROPER: BAREILLY(U.P.) INDIA
CAN ANY ONE TELL ME HOW CAN I SOLVED THESE ERRORS IN HFSS ?
1) The background does not touch the following boundaries "Perf1_INF_GND.This may prouduce an incorrect result
2) Terminals Coax_pin_T1 touch or overlap each other.
3) Port WavePort:The port has no terminals defined on it.
4) Port WavePort1:The number of terminals must be between 1 and 25.
May be you gotta give a little bit more info on ur modal for us to help u out man...
