Manoela Brum
Newbie level 2
Please help me!
I need to send a sms from module at900 for a mobile cell and is returning the error ps busy (if cmee=2) or the error 515 (if cmee=1) when I print the CMGS="number" command.
I know:
'CMS ERROR 515' is received in the following cases:
1. Sending an SMS message when the SIM initialization is going on (after rebooting the module).
2. Reading a SMS immediately after booting the module when the SIM initialization is not over yet.
3. Write a SMS to memory before SIM initialization is complete.
4. Sending more than one SMS at one time or send a SMS when the response (OK or ERROR) for a previously sent SMS has not been received.
Neither of the cases above is the mine, because my preferred storage is empty and there isn't neither command in wait and my module is initialized.
I'm using the following codes:
//First code:
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(2,3);
#define BUF_LEN 84
int statuspin = 4;
int pinState = 0;
int x,y,i,j;
char ncadastrado[] = "555412345678";
char nremetente[] = "";
char codcadastrado[] = "0001";
char codremetente[] = "";
const int MAXDATA1 = 256;
const int MAXDATA2= 256;
char msg1[MAXDATA1];
char msg2[MAXDATA2];
const int MAXDATA = 256;
char data [MAXDATA];
byte num_of_bytes;
byte retorno;
char comm_buf[256];
byte n;
void setup(){
mySerial.begin(19200); // the GPRS baud rate
mySerial.println("AT+CIFSR");//executa comando
delay(3000); //espera resultado na serial
leserial(); //processa dados e armazena no buffer
retorno = IsStringReceived("OK"); // verifica se o retorno é o esperado
Serial.println(comm_buf); //mostra retorno real
limpa_buffer(); //limpa buffer
mySerial.println("AT+CSQ");//executa comando
limpa_buffer();
mySerial.println("at+cstt=\"zap.vivo.com.br\",\"vivo\",\"vivo\"");//executa comando
delay(2000); //espera
limpa_buffer();
mySerial.println("at+ciicr");//executa comando
delay(5000); //espera resultado na serial
limpa_buffer();
mySerial.println("at+cifsr");//executa comando
delay(2000); //espera resultado na serial
limpa_buffer();
mySerial.println("at+cdnscfg?");//executa comando
limpa_buffer();
mySerial.println("AT+CMGF=1\r"); // Because we want to send the SMS in text mode
delay(1000);
mySerial.println("AT+CMGS=\"555412345678\"\r"); // Setting for the SMS Message center number,
delay(1000);
leserial();
limpa_buffer();
mySerial.println("mensagem de teste"); // Start accepting the text for the message
delay(1000);
mySerial.println((char)26);
leserial();
limpa_buffer();
byte IsStringReceived(char const *compare_string)
//Serial.println("testando...");
char *ch;
byte ret_val = 0;
if(1) {
ch = strstr((char *)comm_buf, compare_string);
if (ch != NULL)
Serial.println("existe Valor");
ret_val = 1;
else
return (ret_val);
void limpa_buffer()
memset(comm_buf,'\0',BUF_LEN);
void leserial()
num_of_bytes = mySerial.available(); //Pega quantidade de bytes que estao na serial
while (mySerial.available() > 0) //Espera de até Available ser true
for(n=0; n<num_of_bytes; n++)
comm_buf[n] = mySerial.read(); //armazena buffer e a cada mySerial.read carry on buffer interno
mySerial.flush(); //limpa buffer de entrada da serial
void loop(){}
//Second code:
#include <String.h>
SoftwareSerial mySerial(2, 3);
void setup()
delay(500);
void loop()
if (Serial.available())
switch(Serial.read())
case 't':
SendTextMessage();
break;
case 'd':
DialVoiceCall();
break;
case 'h':
SubmitHttpRequest();
break;
case 's':
Send2Pachube();
break;
if (mySerial.available())
Serial.write(mySerial.read());
///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
mySerial.println("AT + CMGS = \"555412345678\"");//send sms message, be careful need to add a country code before the cellphone number
delay(100);
mySerial.println("A test message!");//the content of the message
delay(100);
mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
delay(100);
mySerial.println();
void ShowSerialData()
while(mySerial.available()!=0)
//the others functions aren't importants.
ALL the codes return the same error: ps busy.
If I use the SoftwareSerialExample code, for print the at commands directly for the module, returns the same error: ps busy.
I try with different hyperterminals and is the same error.
If I use the library for send the message, the dispatch is ok, but I need get send without the library, only with the at commands.
Why is returning this error? What I can do for fix them?
Please help me!
Thank you!
I know:
//First code:
#include <String.h>
#define BUF_LEN 84
int statuspin = 4;
int pinState = 0;
int x,y,i,j;
byte num_of_bytes;
byte retorno;
char comm_buf[256];
byte n;
void setup(){
limpa_buffer();
limpa_buffer();
limpa_buffer();
limpa_buffer();
limpa_buffer();
delay(1000);
delay(1000);
leserial();
limpa_buffer();
delay(1000);
leserial();
limpa_buffer();
char *ch;
byte ret_val = 0;
if(1) {
if (ch != NULL)
ret_val = 1;
else
return (ret_val);
void limpa_buffer()
void leserial()
void loop(){}
//Second code:
#include <String.h>
void setup()
delay(500);
void loop()
case 't':
SendTextMessage();
break;
case 'd':
DialVoiceCall();
break;
case 'h':
break;
case 's':
Send2Pachube();
break;
delay(100);
delay(100);
delay(100);
delay(100);
mySerial.println();
Please help me!
Thank you!
