Hey guys, I suffered some problem while mapping in Xilinx ISE 9.1. And I find there are several similar posts about this problem in Edaboard ,but not any answer.I found some resolutions in Xilinx's website, like
"10.1 Floorplanner - "ERROR
ack:679 - Unable to obey design constraints." (No DRC check on Virtex FF clock)" **broken link removed**
"ERROR
ack:679 - Unable to obey design constraints using ISE 10.1.03."
ERRORack:679 - Unable to obey design constraints... - Xilinx User Community Forums
"9.2i MAP - Master Answer Record for debugging "Pack:679" and "Pack:2811" failures"
"ISE 8.2.3i MAP ERROR
ack:679 - Unable to obey design constraints"
ISE 8.2.3i MAP ERRORack:679 - Unable to obey des... - Xilinx User Community Forums
"6.1i Virtex-II MAP - "ERROR
ack:679 - Unable to obey design constraints..."
And the resolution about the problem 's not the same, like set a new variable or update to a latest one ,etc.
I mapped the FFT256 module in Xilinx ISE 9.1 using Virtex 4 and Virtex 5 devices respectively,and the error suffered only in Virtex5 device .The project specification's like:
Project:
Project Name: FFT256
Project Path: F:\fft_256\route3\FFT256
Top Level Source Type: EDIF
Device:
Device Family: Virtex5
Device: xc5vlx30
Package: ff324
Speed: -1
Synthesis Tool: XST (VHDL/Verilog)
Simulator: ISE Simulator (VHDL/Verilog)
Preferred Language: Verilog
Enhanced Design Summary: enabled
Message Filtering: disabled
Display Incremental Messages: disabled
EDIF Sources:
F:/fft_256/rev_4/fft256.edf copy to Project
Does the situation infer ISE 9.1 not support for Virtex5 device ?How to resolve this message? Anyone suffer the same problem, please help! Also ,if there were some conclusion on this message in different ISE edition, it would be better ,thanks.
