Re: Error message in Pcad2k6sp/Options Design Rules. OS-Vis
I know this is 2008 and your posting is dated 2006, BUT can you (could you) help? I am running PCAD 2006 under Vista and when i load a PCB file, and look at "Options Layers", the layer display is blank! If i look under "current layer:", all of the layers are apparently still there but they do NOT show up in the window so i cannot edit them or "move up" or "move down" layers.
IF someone else has "kicked up dust on this road", i would really like to know how you solved the problem (see attachment).
gak
