robertobaenagalle
Newbie level 2
Hi!
I've written some VHDL code and I got the following error message:
Error: Can't resolve multiple constant drivers for net sensor_sigte[1] at Simulacion_SSI.vhd(104)
Can anybody help me with this?
The code is posted below. If you need the complete program tell me and I'll send you. Of course I have posted here the part of the code I think is necessary for corrections.
Thanks!!!!!
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
ETAPA_ENVIO: process -- LÍNEA 104
begin
wait until (step=2);
case (sensor) is
when 1 =>
control <= "01";
sensor_sigte <= 2;
when 2 =>
control <= "10";
sensor_sigte <= 3;
when 3 =>
control <= "11";
sensor_sigte <= 1;
end case;
irq_aux <= '1';
step_sigte <= 3;
data_paralelo_out <= data_paralelo_aux;
end process;
SINCRO: process (CLK_48M, RESET)
begin
if (RESET='1') then
step <= 1;
step_sigte <= 1;
sensor <= 1;
sensor_sigte <= 1;
elsif ((CLK_48M'EVENT) AND (CLK_48M='1')) then
control_ssi <= control; -- dato de sensor
data_paralelo <= data_paralelo_out; -- dato de posición
time_ssi <= contador_out; -- diferencia de tiempo
irq <= irq_aux; -- señal de interrupción para la CPU
sensor <= sensor_sigte;
step <= step_sigte;
end if;
end process;
Thanks!!!!!
begin
case (sensor) is
when 1 =>
control <= "01";
sensor_sigte <= 2;
when 2 =>
control <= "10";
sensor_sigte <= 3;
when 3 =>
control <= "11";
sensor_sigte <= 1;
end case;
irq_aux <= '1';
step_sigte <= 3;
end process;
begin
if (RESET='1') then
step <= 1;
step_sigte <= 1;
sensor <= 1;
sensor_sigte <= 1;
step <= step_sigte;
end if;
end process;
