Error in schematic after includng bondpad
s_ss
Member level 1
karachi
Hello I am getting the following error after I include bondpad in my design. Can some body help how to remove the error?
Simulating `input.scs' on CadenceLatest at 7:01:53 AM, Fri May 15, 2015 (process id: 19524).
Current working directory: /home/sana/simulation/Testbench_36/spectre/schematic/netlist
Command line:
/usr/local/cadence/installs/MMSIM121/tools/spectre/bin/32bit/spectre \
input.scs +escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_17385_1 -format psfxl -raw ../psf \
+lqtimeout 900 -maxw 5 -maxn 5
spectre pid = 19524
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libphilips_o_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /usr/local/cadence/installs/MMSIM121/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Reading file: /home/sana/simulation/Testbench_36/spectre/schematic/netlist/input.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_ll.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_3.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_nvarrf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_resrf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mimrf.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_ind.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_hs.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_res.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mim.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_dio.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_bjt.scs
Reading file: /usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs
Time for NDB Parsing: CPU = 100.005 ms, elapsed = 604.907 ms.
Time accumulated: CPU = 100.005 ms, elapsed = 604.907 ms.
Peak resident memory used = 25.4 Mbytes.
Warning from spectre in `nmosrf_hs', during circuit read-in.
WARNING (SFE-57): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs" 22: Parameter name `m' is reserved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
Warning from spectre in `pmosrf_hs', during circuit read-in.
WARNING (SFE-57): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150rf_mosrf_hs.scs" 394: Parameter name `m' is reserved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
Reading link: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/discipline.h
Reading file: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/disciplines.vams
Reading link: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.h
Reading file: /usr/local/cadence/installs/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.vams
Opening directory input.ahdlSimDB/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_3.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_3.ahdlcmi/Linux/ (775)
Compiling ahdlcmi module library.
Finished compilation in 1.02 s (elapsed).
Installed compiled interface for bsource_3.
Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_1.ahdlcmi/Linux/ (775)
Finished compilation in 984 ms (elapsed).
Installed compiled interface for bsource_1.
Opening directory input.ahdlSimDB//bsource.va.bsource_2.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_2.ahdlcmi/Linux/ (775)
Finished compilation in 982 ms (elapsed).
Installed compiled interface for bsource_2.
Opening directory input.ahdlSimDB//bsource.va.bsource_4.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_4.ahdlcmi/Linux/ (775)
Finished compilation in 993 ms (elapsed).
Installed compiled interface for bsource_4.
Opening directory input.ahdlSimDB//bsource.va.bsource_5.ahdlcmi/ (775)
Opening directory input.ahdlSimDB//bsource.va.bsource_5.ahdlcmi/Linux/ (775)
Finished compilation in 994 ms (elapsed).
Installed compiled interface for bsource_5.
Error found by spectre in `nmos_ll':`I15.I27.I4.M0', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `tox': Unknown parameter name `delta_n_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `vth0': Unknown parameter name `delta_n_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `nlx': Unknown parameter name `delta_n_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `dvt0': Unknown parameter name `delta_n_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `u0': Unknown parameter name `delta_n_u0_ll' found in expression.
ERROR (SFE-1996): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 19: Parameter `ua_mis': Unknown parameter name `uanll_mis' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `lint': Unknown parameter name `delta_n_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `cj': Unknown parameter name `delta_n_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M0.nmos_ll': parameter `cjsw': Unknown parameter name `delta_n_cjsw_ll' found in expression.
Error found by spectre in `nmos_ll':`I15.I27.I4.M1', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `tox': Unknown parameter name `delta_n_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `vth0': Unknown parameter name `delta_n_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `nlx': Unknown parameter name `delta_n_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `dvt0': Unknown parameter name `delta_n_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `u0': Unknown parameter name `delta_n_u0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `lint': Unknown parameter name `delta_n_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `cj': Unknown parameter name `delta_n_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.M1.nmos_ll': parameter `cjsw': Unknown parameter name `delta_n_cjsw_ll' found in expression.
Error found by spectre in `nmos_ll':`I15.I27.I4.C5', in `ccapn_l':`I15.I27.I4.C5', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `tox': Unknown parameter name `delta_n_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `vth0': Unknown parameter name `delta_n_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `nlx': Unknown parameter name `delta_n_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `dvt0': Unknown parameter name `delta_n_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `u0': Unknown parameter name `delta_n_u0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `lint': Unknown parameter name `delta_n_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `cj': Unknown parameter name `delta_n_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 23: Model `I15.I27.I4.C5.ccapn_l.nmos_ll': parameter `cjsw': Unknown parameter name `delta_n_cjsw_ll' found in expression.
Error found by spectre in `pmos_ll':`I15.I27.I4.M2', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_ll_schematic':`I15.I27.I4', in `lf150_pio1v8Lib_ll_1v8_p_vss_io_ac_80u_ll_schematic':`I15.I27', in `sid_47_schematic':`I15', during hierarchy flattening.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `tox': Unknown parameter name `delta_p_tox_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `vth0': Unknown parameter name `delta_p_vth0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `nlx': Unknown parameter name `delta_p_nlx_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `dvt0': Unknown parameter name `delta_p_dvt0_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `u0': Unknown parameter name `delta_p_u0_ll' found in expression.
ERROR (SFE-1996): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 191: Parameter `ua_mis': Unknown parameter name `uapll_mis' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `lint': Unknown parameter name `delta_p_lint_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `cj': Unknown parameter name `delta_p_cj_ll' found in expression.
ERROR (SFE-1999): "/usr/local/cadence/installs/PDK_LF150i_V2_0_0/analog/models/spectre/lf150_mos_ll.scs" 195: Model `I15.I27.I4.M2.pmos_ll': parameter `cjsw': Unknown parameter name `delta_p_cjsw_ll' found in expression.
Time for Elaboration: CPU = 384.024 ms, elapsed = 5.41809 s.
Time accumulated: CPU = 484.029 ms, elapsed = 6.02319 s.
Peak resident memory used = 35 Mbytes.
spectre terminated prematurely due to fatal error.
This is urgent. Please help.
Thanks and Regards
sarge
Full Member level 3
Hi
It seems that you don't include model of mos transistor, which is placed in your pad.
Reactions: s_ss
    s_ss
s_ss
Member level 1
karachi
Thank you for the repl. Yes this was actually the problem. I included the model and now I can work. Thanks
