Error in mplab icd2 regarding invalid target device id
dspic30f
Newbie level 3
I am using mplab icd 2 programmer for programming dspic30f4012 controller..
I gave all the supply connections correctly but i am getting the following error.
Auto-connect not enabled - Not connecting (Try enabling auto-connect on the ICD2 settings pages.)
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to target
ICDWarn0020: Invalid target device id (expected=0x100, read=0x0)
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 ready for next operation
Someone please help me..I am not able to debug.I am in a very crucial ctage of my project
Re: regarding mplab icd2
Is this a bread broad prototype or a development board?
The ICD is not seeing the dsPIC, is it powered up or are you trying to supply the project power via ICD?
I made the circuit on breadboard...The pic is powered from external supply
Can you post a schematic?
Have you specified the correct PIC model in MPLAB?
Make sure you disable the power to target option in ICD2 configuration dialog.
Exit MPLAB, unplug and replug the ICD2 into USB port
Restart MPLAB and select ICD2 debugger or programmer.
This is particular troublesome if indeed autoconnect is selected:
These are procedures I have used in the past to correct ICD2 problems.
I cannot post the schematic...but its just simple.I gave the following connections.
Vdd-5v,Vss -ground,4Mhz crystal at osc pins.Avdd-Vdd.AVss-Vss and i gave the connections from icd 2.
I have specified the pic in mplab.I unchecked the 'power target from icd2;auto connect in not enabled....
I tried to use dspic30f 4011.Then also,I was getting the same problem..I changed the RS232 cable.Then,my device is detected but programming is failed.I got the following output.
...Connected
Target Device dsPIC30F4011 found, revision = Rev 0x1002
...Passed
Programming Target...
...Validating configuration fields
...Erasing Part
...Programming Programming Executive
...Verifying Programming Executive
ICD0161: Verify failed (MemType = Test, Address = 0x800000, Expected Val = 0x40080, Val Read = 0x80)
ICD0275: Programming failed.
Have you tried using the USB connection? If not, give it a try and enable autoconnect.
---------- Post added at 19:14 ---------- Previous post was at 19:12 ----------
What is the exact model of dsPIC you're using?
