JitterJaw
Newbie level 6
Hi all,
Im running a monte carlo simulation on virtuoso IC6.1.3.500.18. Im using the "clip" and "cross" functions in order to calculate fall time, and it works fine when I use vdd = 0.6 V, when I lower my vdd to 0.3 V the voltage does not drop to the defined cross value, hence the calculated cross value is 'nil' and it stops the simulation saying : *Error* difference: can't handle (nil - 1.275e-06)
How can I force it to ignore the nil results, and only display the right calculations, noting the change in the 'N=' referance of the monte carlo results ?
THX in advance
THX in advance
