Dec 12, 2014 #1 S Saket Karve Newbie level 1 Joined Dec 12, 2014 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 22 this is the header file i got when i brought a line follower kit which has P89V51RD2FN 8051 based microcontroller.....please let me know whats the mistake Code dot - [expand]1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 //LCD Header #ifndef __LCD_H__ #define __LCD_H__ #define RS P00 /*0 for Command , 1 for Data */ #define RW P01 /*0 for Write , 1 for Read */ #define EN P02 /*Pulsed for completing an operation */ code unsigned char PUTLINE2 = 0x0C0; /*Address for line 2 */ code unsigned char PUTLINE1 = 0x80; /*Address for line 1 */ code unsigned char DISPON = 0x0c; /*Command turning on display*/ code unsigned char CURSORHOME = 0x02;/*Command for puttin cursor on home position*/ #include<reg51.h> #include<delay.h> void LCD_WRITE(unsigned char dat); void LCD_CMD(unsigned char cmd); void PULSE(void) { P02 = 1; delay(5); EN=0; } void LCD_CMD(unsigned char cmd) // Give Command to LCD { P0=0x00; EN=0; RS=0; RW=0; P0=((cmd&0xF0))|(0x08); // Higher nibble first PULSE(); P0=(((cmd&(0x0F))*16))|(0x08); // Lower nibble next PULSE(); } void LCD_STRING (unsigned char str[17]) { unsigned char k=0; P0=0x01; EN=0; RS=1; //Operation is data write RW=0; while(str[k]!='\0') //Till null character is encountered { P0=((str[k])&0xF0)|0x09; PULSE(); P0=((str[k]&(0x0F))*16)|0x09; PULSE(); k++; } } void LCD_WRITE(unsigned char dat) { unsigned char datH=0,datL=0; P0=0x01; EN=0; RS=1; //Operation is data write RW=0; P0=(dat&0xF0)|0x09; // Higher nibble first PULSE(); P0=((dat&(0x0F))*16)|0x09; // Lower nibble next PULSE(); } void LCD_INIT(void) //LCD Initialization { EN=0; RS=0; RW=0; P0=0x20; //4bit mode PULSE(); LCD_CMD(0x01); LCD_CMD(DISPON); LCD_CMD(CURSORHOME); } /* void LCD_MENU(unsigned char MAINMENU[2][17],r) { unsigned char m=0,n=0; LCD_CMD(PUTLINE1); for(m=0;m<2;m++) { for(n=0;MAINMENU[m][n]!='\0';n++) { LCD_WRITE(MAINMENU[m][n]); } LCD_CMD(PUTLINE2); } } */ void LCD_CLEAR(void) //Clear LCD { LCD_CMD(0x01); } void LCD_DATA(unsigned char num) { unsigned char array[3]; int j=0; array[2]=0; array[1]=0; array[0]=0; while(num>0) { array[j]=num%10; num=num/10; j++; } LCD_WRITE(array[2]+48); LCD_WRITE(array[1]+48); LCD_WRITE(array[0]+48); } error:- 'P02' : Undefined Identifier for every line where EN, RS & RW is written Last edited by a moderator: Dec 12, 2014
Dec 16, 2014 #2 U ud23 Advanced Member level 3 Joined Apr 20, 2011 Messages 926 Helped 185 Reputation 370 Reaction score 180 Trophy points 1,323 Activity points 6,138 Which compiler you are using if you have nxp chip then include the Phillips header file in place of reg51.h and just try below thing Code: #define RS P0^0 /*0 for Command , 1 for Data */ #define RW P0^1 /*0 for Write , 1 for Read */ #define EN P0^2
