error in eldo simulation
Anil54321
I'm trying to simulate a circuit involving BJT and diodes. What is the device name i should use?
im using Pyxis schematic as the tool.
the error is: Q1 PNP is not defined.
pls help me out
.INCLUDE the library which contains the PNP transistor (and others).
which library to add?
i cant find any library for those devices.
Could you show your netlist, pls?
1453969558602.jpg this is the netlist
Your ELDO setUp should contain a library with the primitive BJT PNP. Try and find it, and insert
.INCLUDE [I]this library[/I]
in your netlist. Without a definition for the PNP, ELDO can't work.
I cant find any library for them. Could you pls give me an example of such a library?
else, where can i get those libraries?
thank you
