library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity verifier is
Port ( clk : in std_logic;
sum : in std_logic_vector(3 downto 0);
cy : in std_logic;
aout : out std_logic_vector(3 downto 0);
bout : out std_logic_vector(3 downto 0);
cout : out std_logic;
chkout : out std_logic_vector(7 downto 0));
end verifier;
architecture Behavioral of verifier is
component full_adder
Port( a : in std_logic_vector(3 downto 0);
b : in std_logic_vector(3 downto 0);
cin : in std_logic;
clk : in std_logic;
s : out std_logic_vector(3 downto 0));
end component;
component comparator
port( a :in std_logic_vector(3 downto 0);
b :in std_logic_vector(3 downto 0);
cin :in std_logic;
clk :in std_logic;
cout :in std_logic;
s :in std_logic_vector(3 downto 0);
chkr :out std_logic);
end component;
begin
process(clk)
variable a_var,b_var : std_logic_vector(3 downto 0):="0000";
variable chk,c_var : std_logic;
variable chk_temp : std_logic_vector(7 downto 0);
begin
a_count:for i in 15 downto 0 loop
a_var:=a_var+1;
b_count:for j in 15 downto 0 loop
b_var:=b_var+1;
cout_count:for k in 1 downto 0 loop
if(k=0) then
c_var:='0';
else c_var:='1';
end if;
aout<=a_var;
bout<=b_var;
cout<=c_var;
fa :full_adder port map(aout,bout,cout,cy,clk,sum); --Problem comes in this line
cmp:comparator port map(aout,bout,cout,clk,cy,sum,chk); --Problem comes in this line
if(chk='1') then
chk_temp:=chk_temp+1;
end if;
end loop cout_count;
end loop b_count;
end loop a_count;
chkout<=chk_temp;
end process;
end Behavioral;
