traxex
Hi. I'm using pic16f877. When i try to build project with this code, i get an error saying expression syntax where there is "PORTA=i". What does that mean? What is the mistake?
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 #include <pic.h> #include <delay.c> main(void) { unsigned char sequence[40]; unsigned char i,a,column; signed int slide,value; unsigned const char text[]={ 0x00,0x00,0x1E,0x03,0x7E,0xCC,0x76,0x00, //a 0x00,0x00,0x66,0x3B,0x33,0x60,0xC0,0x00, 0x00,0x00,0x1E,0x33,0x60,0x66,0x3C,0x10, 0x00,0x00,0x3E,0x63,0xFE,0xC0,0x78,0x00, 0x0C,0x0C,0x18,0x18,0x30,0x30,0x70,0x00, 0x06,0x00,0x18,0x18,0x30,0x30,0x60,0x00, 0x18,0x18,0x33,0x36,0x7C,0x66,0xC3,0x00}; column=50; TRISB=0; TRISA=0; ADCON1=0x07; PORTB=0x00; for(;;){ for(i=0;i<=39;i++){ sequence[i]=0; } for(slide=-38;slide<=column;slide++){ for(i=0;i<=39;i++){ value=i+slide; if(value<0)sequence[i]=0; if(value>=0&&value<=column-1) sequence[i]=text[value]; if(value>column)sequence[i]=0; } for(a=0;a<40;a++){ for(i=0;i<=15;i++){ PORTB=sequence[i] PORTA=i; DelayUs(200); }}} } }
