Error Expecting a declaration in CCS
Osawa_Odessa
Banned
Full Member level 3
Hello,
I need your help again. I am trying to measure humidity using HS1101, pic 16F877A and CCS compiler. I have the code bellow but when I try to compliler it, there are too many error that I can't fix it.
Here is the code:
#include "main.h"
#include "var.h"
#include "lcd16x2/lcd16x2.c"
#include "hs1101/hs1101.c"
#INT_RTCC
void  ngat_timer0(void)
   disable_interrupts(GLOBAL);
   set_timer0(5);
   count++;
   if(count==78)
      frequency=get_timer1();
      set_timer1(0);
      count=0;
      enable_display=1;
   enable_interrupts(GLOBAL);
void main()
uint8_t str[20],humi;
DDRB=0xfe;
   DDRD=0x00;
   DDRE=0x00;
   LCD_Init();
   setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
   sprintf(str,"BanLinhKien.Vn");
   LCD_Puts(str);
   delay_ms(4000);
   set_timer0(5);
   set_timer1(0);
   enable_interrupts(INT_TIMER0);
while(TRUE)
     if(enable_display)
     humi=HS1101_GetHumi(frequency);
     enable_display=0;
     sprintf(str,"Do Am:%3u",humi);
     LCD_Gotoxy(0,1);
     LCD_Puts(str);
     LCD_PutChar('%');
Here there are many errors like this:
*** Error 28 "C:\USer\Odessa\Deskop\CCS\main2\var.h" Line 18(17,25): Expecting a (
...Expecting a declaration
  • code.rar
The problem is in var.h file. Maybe some declarations are missing. Remove #include "var.h" and put the below lines in your main file and make then global variables and see if it works.
uint16_t frequency=0;
uint8_t enable_display=0;
uint8_t count;
hello:
I use during the training period, the ML501 Vertex5 to design a MPSoCs (multiprocessor on chip), and I'll ENTERING AND the environment EDK 10.1 release for the design of two MicroBlaze processors .. .
Please, if possible, send me a guide or totorial for these dual MicroBlaze processors.
and thanks
hello:
I use during the training period, the ML501 Vertex5 to design a MPSoCs (multiprocessors on chip), and I'll ENTERING AND the environment EDK 10.1 release for the design of two MicroBlaze processors .. .
and thanks
Bonjours:
Est ce que le fait de créer deux microblaze avec leurs périphériques sans aucune modification du code en utilisant l'outil de xilinx EDK ,permettre de dire qu'on a achevé la partie matérielle ? et qu'il faut juste la transformér en flux binaires el l'exporter au fpga via le jtag ??
et merci.
Bonjours:
et merci.
Bonjours:
et merci.
