hassantalal785
Newbie level 6
HELLO i am using a jtag-parrallel Cable III......TO CONFIGURE a SPARTAN 3A 1800 FPGA STARTER PLATFORM.... I GET THE ERROR : '1' Programming terminated.DONE didnot go high.
complete text apperaing in PROJECT NAVIGATOR space is :
// *** BATCH CMD : loadProjectFile -file "C:\Documents and Settings\Administrator\Desktop\tset2\salman/salman.ipf"
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS 12:35:07, version = 811.
LPT base address = 0378h.
ECP base address = 0778h.
Cable connection established.
'1': Loading file 'C:/Documents and Settings/Administrator/Desktop/tset2/salman/ss.bit' ...
done.
INFO:iMPACT:1777 -
Reading C:/Xilinx/10.1/ISE/spartan3adsp/data/xc3sd1800a.bsd...
INFO:iMPACT:501 - '1': Added Device xc3sd1800a successfully.
Active mode is BS
// *** BATCH CMD : setMode -ss
// *** BATCH CMD : setMode -sm
// *** BATCH CMD : setMode -hw140
// *** BATCH CMD : setMode -spi
// *** BATCH CMD : setMode -acecf
// *** BATCH CMD : setMode -acempm
// *** BATCH CMD : setMode -pff
// *** BATCH CMD : setMode -bs
// *** BATCH CMD : addDevice -p 2 -file "C:/Documents and Settings/Administrator/Desktop/NEW/test1_cw.bit"
'2': Loading file 'C:/Documents and Settings/Administrator/Desktop/NEW/test1_cw.bit' ...
done.
INFO:iMPACT:501 - '2': Added Device xc3sd1800a successfully.
// *** BATCH CMD : cutDevice -p 2
Attempting to identify devices in the boundary-scan chain configuration...// *** BATCH CMD : Identify
PROGRESS_START - Starting Operation.
Identifying chain contents ....'1': : Manufacturer's ID =Xilinx xc3sd1800a, Version : 0
done.
PROGRESS_END - End Operation.
Elapsed time = 0 sec.
// *** BATCH CMD : identifyMPM
// *** BATCH CMD : assignFile -p 1 -file "C:/Documents and Settings/Administrator/Desktop/NEW/test1_cw.bit"
'1': Loading file 'C:/Documents and Settings/Administrator/Desktop/NEW/test1_cw.bit' ...
done.
// *** BATCH CMD : Program -p 1 -prog
Maximum TCK operating frequency for this device chain: 0.
Validating chain...
Boundary-scan chain validated successfully.
'1': Programming device...
done.
'1': Reading status register contents...
CRC error : 0
IDCODE not validated while writing FDRI : 0
DCM matched : 0
status of GTS_CFG_B : 0
status of GWE : 0
status of GHIGH : 0
value of VSEL pin 0 : 0
value of VSEL pin 1 : 0
value of VSEL pin 2 : 0
value of MODE pin M0 : 0
value of MODE pin M1 : 0
value of MODE pin M2 : 0
value of CFG_RDY (INIT_B) : 0
DONEIN input from Done Pin : 0
POST_CRC_ERR error : 0
SYNC word not found : 0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT - '1': Checking done pin....done.
'1': Programming terminated. DONE did not go high.
Elapsed time = 36 sec.
please helpppp
done.
INFO:iMPACT:1777 -
Active mode is BS
done.
done.
done.
Validating chain...
done.
CRC error : 0
DCM matched : 0
status of GWE : 0
status of GHIGH : 0
please helpppp
