error C1016: #if[n]def expected an identifier & IntelliSense: expected an identifier
klun
Junior Member level 2
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#ifndef (__BIG_ENDIAN__) and !define (__LITTLE_ENDIAN__) *Error in this line*
#define __LITTLE_ENDIAN__
#endif
namespace {
union Converter32 {
  uint32_t bit_32;
  struct {
#ifdef __LITTLE_ENDIAN__
    uint8_t byte3;
    uint8_t byte2;
    uint8_t byte1;
    uint8_t byte0;
#else
    uint8_t byte0;
    uint8_t byte1;
    uint8_t byte2;
    uint8_t byte3;
#endif
Can someone help me on the errors?
Re: error C1016: #if[n]def expected an identifier & IntelliSense: expected an identi
should it be
#ifndef __BIG_ENDIAN__
#ifndef __LITTLE_ENDIAN__
#endif
#endif
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#endif
namespace {
union Converter32 {
  uint32_t bit_32;
  struct {
    uint8_t byte3;
    uint8_t byte2;
    uint8_t byte1;
    uint8_t byte0;
#else
    uint8_t byte0;
    uint8_t byte1;
    uint8_t byte2;
    uint8_t byte3;
#endif
Code C - [expand]
#if !defined(__BIG_ENDIAN__) && !defined (__LITTLE_ENDIAN__)
#endif
