[SOLVED] Equivalent circuit of a printed loop antenna
Nano_o
Member level 2
Hello everyone !
I would like to model my patch antenna under its equivalent circuit form, but I don't know how to combine the already existing model of a loop antenna with my model which include a partial ground plane and a microstrip feed line.
I will be grateful if you could help me or give me some recommendations of useful references or links.
Thank you in advance! : grin:
FvM
Super Moderator
Staff member
Bochum, Germany
Depends on how your present circuit looks like.
A partial ground plane may be represented by a coupled lossy inductance plus possibly a parallel capacitance, the feed line as an ideal or lossy transmission line...
Reactions: Nano_o
    Nano_o
Nano_o
Member level 2
thank you for your answer FvM,
my antenna is a square loop patch antenna.
concerning the feed line it is not an ideal one, but if you do not mind could you please tell me how to model both cases!
thank you :thumbsup:
FvM
Super Moderator
Staff member
Bochum, Germany
I was thinking of the ideal and lossy transmission line models in circuit simulation programs, e.g. SPICE.
It's important to understand if transmission line common mode waves are involved, if so a combination of multiple transmission line models may be used to model common mode and differential waves.
What's the frequency range of your antenna?
Reactions: Nano_o
    Nano_o
Nano_o
Member level 2
Thank you once again for your reply FvM,
I beg your pardon but I would like to know if I get the meaning of your sentence "It's important to understand if transmission line common mode waves are involved," did you meant that the antenna has multiple resonance frequencies if so yes the antenna is a multiband with a frequency range
3 GHz- 50 GHz.
FvM
Super Moderator
Staff member
Bochum, Germany
Common mode waves would be involved if a transmission line is e.g. connected single ended at one and differentially ended at the other end without a suitable balun.
Reactions: Nano_o
    Nano_o
Nano_o
Member level 2
Thank you very much! well.. yes in my case the common mode waves are involved :oops:
Nano_o
Member level 2
Hello,
volker@muehlhaus it is a loop antenna actually.
thanks!
