Hi
I need help and advice regarding how to secure that a plant is properly grounded. Where I live there are numerous pipes, tubes needed to be grounded, this due to risk of explosion if there are a discharge.
Are there any commercial systems that monito proper grounding, as it is now it is not grounded most of the time. Personell doing a repair do not attach cabling as supposed and if something happens there will be insurance problems.
If there are no commercial equipment I wonder if someone has help to give. The problem is that all equipment ends up as a giant meshnet.
The best would be some automatic indication that some part or area in the plant has a n grounding error but any advice where to start are welcome.
Thank you in advance
Cl
