Encounter tcl commands
cyrax747
Full Member level 3
Full Member level 3
Bangalore
Hi all
I need soc encounter tcl commands to run my flow from netlist to gds. Could you please help me regarding this??
In the Encounter Manual you will find all the commands you need. There will also be a sample TCL script. Use that script as a base script and then customize it as per your design flow.
Are u talking about user guide , if so i have one.Can you be more specific exactly which portion i have to look in to ??
In most cases there are two docs, an user guide and a command reference. It seems to me that you would need the command reference guide.
Browse through the installation dir. of Encounter and there should be a folder named /doc. Else as per your company policy it might be in a special docs section on a common server.
To save time ask the tool admin person of your company or your team-lead may know it. :)
1> I don't work with Cadence tools suite right now.
2> Even if I would have the doc, as per the forum rules, it is forbidden to share copyrighted materials.
I cannot comprehend a good reason why someone from your team will not give you the info where such a document is located!
