I HAVE A PROJECT TO MEASURE DISTANCE IN A ROBOT THAT USE INDUCTIVE SENSORS FOR ENCODERS.
AND THE ROBOT IS REMOTELY CONTROLLABLE.(THAT PART IS ALREADY DONE,)
MY PROBLEM IS TO GET THE DISTANCE ROBOT TRAVELED USING ENCODERS,
I NEED TO CONSIDER ABOUT THE TURNING PART AS WELL.
THANKS FOR ANY IDEA!!
USING ALL CAPS MEANS SHOUTING IN INTERNET LANGUAGE MODERATOR ACTION: MODERATOR ACTION:
what all things you tried?
i think you use two encoders if you want to measure the turning parts
else you connect the encoder to the wheel of the robot, calibrate that for 1 rotation
in distance. now start counting the distance
what are the problems that you are facing?
please post it then only anyone can help you
