Enable Autorouting in Orcad Layout.
Does anyone know how to enable Autorouting in Orcad Layout.
what about the picture??
Thanks Nikhil! But my query was for certain layouts where the above mentioned option is completely disabled.
it may be any PCB software i recommend manual routing...why don't you use eagle instead of orcad??
component placement is important
Hey Nikhil, How do I upload a .max file in this forum?
Else, I could email the file to you..
Thanks!
zip the max file.
Click on 'Go Advanced' .. there you will get to upload files
hi,
in my system autorouting option is available with your board and I successfully autoroted it.(check the image).
And your grid settings seems too small. Change all grids to 0.127mm from Option--> sysytem settings. this may work for you.
