Emulated DDR flip flop
shaiko
Advanced Member level 5
process ( clock ) is
  begin
    if rising_edge ( clock ) then
       Q1 <= D ;
    end if ;
  end process ;
  begin
    if fallng_edge ( clock ) then
       Q2 <= D ;
    end if ;
  end process ;
Q_DDR <= Q1 or Q2 ;
1.Any reason for the above not to work in an FPGA ?
2.Is there a syntax to describe a VHDL DDR flip flop ?
For example, I know that the following won't work :
if rising_edge ( clock ) or falling_edge ( clock ) then
   Q_DDR <= D ;
end if ;
neither wil
   Q_DDR <= D ;
elsif falling_edge ( clock ) then
   Q_DDR <= D ;
end if ;
But why ?
Both of the above describe the behavioral model of a DDR flip flop.
But why ?
VHDL and Verilog are simulation languages. It is easy to write code that is impossible or difficult to synthesize. Your examples are difficult. Try to draw a schematic manually, using normal gates and flip-flops. You will probably understand why the tool can't do it.
I know that such flip-flops are available in some technologies, but I don't know if your examples will compile. The tool may require that the code is written in a special way.
Reactions: shaiko
    shaiko
Its going to depend on the technology. Afaik, All FPGAs from the main vendors are single edge triggered only (accross the entire chip), with maybe some DDR ffs in hard cores that require them. If you were compiling for an ASIC, the code would be perfectly fine.
The only way to get a DDR FF in an FPGA is to run a clock at 2x main clock speed.
Reactions: shaiko
    shaiko
The correct behavioral desription of the DDR output registers availble in recent FPGAs involves a multiplexer, not an OR gate. For bidirectional DDR pins, a respective OE control has to be added.
Besides reasonability considerations, it's always possible to have FFs clocked on different edges in a design. It's also possible to implement an "emulated" DDR FF block. The interesting question is about the required output timing, acceptance of glitches etc.
Reactions: shaiko
    shaiko
