Yes,the schematic is of a TI Evaluation board. I was facing issue in determining the value of L1 and for that i need to know how the value needs to be calculated.The schematic looks like being copied from TI evaluation board user guide https://www.ti.com/lit/ug/sluuax9b/sluuax9b.pdf, curiously with the common mode choke inductance value deleted.
L1 and C1 can be considered as EMI filter elements.
Allthough L1 is a common mode choke, it has some differential inductance and is in so far filtering differential mode interferences in combination with C1. The common mode inductance is acting in combination with line common mode impedance.
What could be the alternative for this EMC filter in this design?the DM inductance of the CM choke ( usually about 5% ) forms a DM filter with the cap on the mains, the CM choke attempts to reduce CM ( common mode ) noise to the mains - it is an EMC filter - but perhaps not a very efficacious one.
