EMC SIMULATION WITH HYPERLYNX
HAIFA86
Tunisia
I want to do the EMC simulation of a PCB with Hyperlynx
I chose a net between two ICs: a microcontroller without any digital peripherial and an analog IC(AD8361 et R8C/L38A).
I charged the ibis models of both of them, however when I simulate there is no signal.
Is the problem the fact that the signals between the two ICs are analog?
please Ireally need help.
thanks
steli.filipov
Newbie level 2
Hi HAIFA86,
When you say there is no signal... do you mean there is no waveform in the Digital Oscilloscope, or there are no harmonics in the Spectrum Analyzer?
For both cases... did you try "playing" a little bit with the scale buttons?
What kind of driving signal did you use?
If you have a waveform in the Oscilloscope, then you MUST observe some EM radiation in the Spectrum Analyzer.
If you are sure everything is alright... try using another IBIS models and see what happens.
HAIFA86
Tunisia
thank you but I juste found the problem.
the problem is that in my PCB ther is no ground plane as reference so there is no harmonics in the Spectrum Analyzer.
filtemc
Banned
#9 Lanxiang Road,Tianqiao Industrial Area
AC PCB series filters
1.Features & Appliactions:
Low leakage current,and effectively suppress the noise interference on line to line and line to ground.
Plastic and metal cover,specially designed for PCB.
Small size,compact structure,easy to install and high performance/price ratio.
Rated current:0.5A-6A.
Suitable for exchange machine,alarm,controller,LCD,satellite TV system and other microminiature equipments.
2.Technical data:
Rated voltage:110/250VAC
Test voltage:1760VDC(line to line) and 2000VAC(line to ground).
Climatic category:25/085/21.
Operating frenquency:50/60Hz.
Insulation resistance:>200MΩ@500VDC.
3.Tabulates
FT110P-0.5:0.5A(Ratedcurrent),
<0.5MA(Leakagecurrent250VAC/50Hz),Fig.1(Dimension),
Fig.1(Electrical schematics),Pin (Termination),0.035Kg(Weight).
FT110P-1:1A(Ratedcurrent),
FT110P-3:3A(Ratedcurrent),
FT110P-6:6A(Ratedcurrent),
FT120P-1:1A(Ratedcurrent),
<0.5MA(Leakagecurrent250VAC/50Hz),Fig.2(Dimension),
Fig.2(Electrical schematics),Pin (Termination),0.04Kg(Weight).
FT120P-3:3A(Ratedcurrent),
FT1200P-1:1A(Ratedcurrent),
<0.5MA(Leakagecurrent250VAC/50Hz),Fig.3(Dimension),
Fig.3(Electrical schematics),Pin (Termination),0.075Kg(Weight).
FT1200P-3:3A(Ratedcurrent),
If you want to get information about Dimension and outline drawing, Electrical schematics,Insertion loss(dB),please contact with Filtemc Electronic Equipment Co.,Ltd.
5.DC PCB series filters
1.Features & Apllications:
DC power filter can effectively suppress the noise interference on line to line and line to ground.
Suitable for DC miniature electronic equipments.
2.Technical data:
Rated voltage:110/250VDC
Test voltage:160VDC(line to line) and 500VAC(line to ground).
Operating frenquency:DC
Insulation resistance:>60MΩ@60VDC.
3.Tabulates
FT110PD-0.5:0.5A(Ratedcurrent), Fig.1(Dimension),Fig.1(Electrical schematics),
FT110PD-1:1A(Ratedcurrent), Fig.1(Dimension),Fig.1(Electrical schematics),
FT110PD-3:3A(Ratedcurrent), Fig.1(Dimension),Fig.1(Electrical schematics),
FT110PD-6:6A(Ratedcurrent), Fig.1(Dimension),Fig.1(Electrical schematics),
FT120PD-1:1A(Ratedcurrent), Fig.2(Dimension),Fig.2(Electrical schematics),
FT120PD-3:3A(Ratedcurrent), Fig.2(Dimension),Fig.2(Electrical schematics),
FT1200PD-1:1A(Ratedcurrent), Fig.3(Dimension),Fig.3(Electrical schematics),
FT1200PD-3:3A(Ratedcurrent), Fig.3(Dimension),Fig.3(Electrical schematics),
