Embedded Systems and Real-Time OS
palpandi461
Newbie level 3
Hi all,
Am doing a project in 4.3" TFT LCD, driven by Renesas Microcontroller. The High performance Embedded Workshop(HEW) compiler is used to modify the software(C coding). The objective is display a image(Bitmap format) on LCD. Using Segger-emWin bitmap converter, i have converted the bitmap image into C file which has the equivalent Hexadecimal value for the each color pixels. My question is how can we manipulate the codes of HEW and the C file which is derived from emWin converter?
By writing image data into frame buffer area
THanks for your support....
The code of converted image data has the equivalent hexadecimal value of each color pixels and HEW has certain API functions to access/manipulate the bitmap image. So we cant directly write the image data into frame buffer area....
