embedded linux or RTOS
Manish Sharma
Newbie level 6
rtos+linux
hi there
i ve do a project in embedded linux or RTOS so can anyone tell me what should i do which are the hot streams and how to begin . Please suggest me the appropriate books.
please give me exact topic and links for detail information bout that so lets see what u suggest
which is the right choice should i go for VxWorks or embedded luinx
embedded linux ftp server source code
I suggest embedded linux in fpga platform with soft-processor such as nios or microblaze. The opensource of embedded linux would reduce quite a number of cost in your design and development.
ucos vs embedded linux
I THINK UCDOSII better
ecos nios ii sourceware
linux is not write for embedded use. so maybe it is not very good for u to understand the RTOS.
I think u can start with ucos2.
linux rtos book
can you plz give me the details for UCOS where i can found it and what is it in brief :eek:
microc os ii linux
hi nishu
this forum is good and thanks for telling me i had downloaded 3 books from it . they are free of points and if you wish too you can go to wotans post in the thread initiated by v kumar and can download them
they are worth a catch!
ucos example xscale
test case studies in the book is a model of the DLX processor
ixp425 rtos ecos
uClinux building for intel arm xscale example (how to).
I've got a second hand version of "Embedded Systems MicroC/OS-II RTOS Kernel" by Jean Labrosse. It no longer has CD at back (probably lost). Is there an ftp site to download latest uC/OS-II source code from ??
thanx mikem
h**p://ixp4xx-osdg.sourceforge.net/howtos/uClinux-IXP400-AccessLibrary-v1.2.2-Integration-
Correct link:
hi
how is your embedded going on and did you get those books downloaded.
if you come across any good book on embedded do refer it to me
bye
hi there ,
thanx for such a useful discussion all of you . i ve down loaded the ecosII and new the documentation(Pdfs ) for study if you know......
the link
https://ecos.sourceware.org/getstart.html is good and bhaiya i ve not found ther books if you know copy the form and send it to me .
