embedded c code for GSM receiving code....
ganesh dvk
Junior Member level 1
chennai
hi seniors,
am trying the data to gsm modem to gsm modem ...i have a problem with the receiving path in gsm and to split the data from micro controler .....tis a problem...any one help tis code..any sample ..pls send seniors.....
which is the controller you are using,
which is C compiler u are using..........
What does this mean? You have a problem on the antenna path of the layout design?
Sorry, I cannot suspect what problem could that be. Is it with the received data via UART?
What microcontroller and what GSM modem are you using?
pic16f877a interface with max232 and rs232 to be connect the wavecom modem send the data after receiving is my problem?
