let's assume that V1 = 0, V2 = 5, R3 =5, R2=10 and R1=10
so the equivalent circuit (R1 will be in parallel with R2) will be in series with R3 and RT = R3 + (R1||R2) = 5 + 5 ; so VA = V2/2 => VA =5/2 =2.5
the formula VA = (V1-V2 ) * R3 /(R3 + R1) produces : -5 *5/(5+10) = -1.66 :?:
mabauti,
Millman had you in mind when he developed "Millman's Theorem". It covers exactly the kind of problem you describe, except it is more general in that it covers networks with an arbitrary number of voltage sources. See, for example
h**p://www.allaboutcircuits.com/vol_1/chpt_10/5.html
Regards,
Kral
hi..u can do this by
1. by using superposition
2. by using kvl and ohms law
1. in supersition first set v1=0 and find VA.
next set v2=0 and find vA.then add both VA values to get total vaue. b careful with current directions.
2. u can apply kvl for path R1,mid resi. while using kvl curr thro mid resi should b i1+i2.
