tahir4awan
Full Member level 4
Electrons movement from Base to Collector in NPN transistor
What causes the electrons to move from base to collector in common emitter configuration. It is said that base is very thin so few electrons from emitter region will diffuse into base and rest of the electrons will move to collector region.
If the purpose of the thin base is only that then what is the function of positive supply at base?
