nickagian
Member level 4
- Joined
- Mar 19, 2009
- Messages
- 71
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Location
- Zurich, Switzerland
- Activity points
- 2,001
Hi!
I would like to do the following:
I want a way to create a negative capacitance, whose value can be controlled electronically. One way that I have thought of doing this is to use a NIC with an input impedance of Zin = -kC, where C will be a known capacitor. If the k can be electronically controllable, then I have the controllable capacitance I want.
But I have some difficulties in how to make this k to be controllable.
(a)One solution would be to use k purely resistive (for example in an opamp NIC) but then I have the problem of how to create an electronically controllable resistance. Any idea here?
(b)Another solution would be to make factor k to depend on some biasing current/voltage. This maybe can be done with a transistor-based NIC? How can then the k depend on the biasing? Can anyone give me a schematic? I have searched in the internet, but haven't found something useful.
Can anyone help me with some ideas on the two points above? Or even a different idea on how to create the variable capacitance, negative or positive?
Thanks!
Thanks!
