Note: This feature currently requires accessing the site using the built-in Safari browser.
vfone said:If the switch is in the high isolation state (>20dB) where the VSWR is high, that means is reflective.
There are some options where using a combination of multiple switch contacts, to terminate for example the isolated port with 50 ohms and become absorptive.
In this way the switch is absorptive regardless the state position.
Also, the absorbitive one has slightly worst VSWR along through line.
