T
treez
As you know, The equation (5) of page 13 of this…
https://www.cde.com/resources/catalogs/AEappGUIDE.pdf
..is what governs wet electrolytic capacitor lifetime...
Its not clear in many wet electrolytic capacitor datasheets, when they say “2000hrs at 105degC”. Do they mean “105degC ambient”, or “105degC case temperature”, or “105degC internal core temperature”?
The other problem with wet electrolytics is of course related to the potential for the electrolyte to simply leak out. This exerpt from cornell dubilier shows the problem with short term high temperature transients in wet electrolytics….
….so this is the problem, can we be sure that our customer won’t ever temporarily operate the product in such a hot ambient that this temporary overheating of the Electrolytic capacitor occurs?
Another point, is, in Equation (5) above…all those temperature parameters depend on knowing what is the internal ambient temperature in the power supply enclosure. Do we really know where the customer is going to use it, and how hot it may become (even for only short intervals).
In any case, the internal ambient temperature in a 60W , “fully enclosed plastic case” offline power supply can easily get above 105degC when the external ambient is just 30degC.....and 105degC is the max temperature of the majority of electrolytic capacitors.
Then there’s the storage history of the electrolytic capacitor… before being sold, it may have already been stored for years in a hot warehouse, but they pretend they are new capacitors, and fiddle the date code, if there is even a date code.
Lop = Mv × Lb × 2^((Tm – Tc)/10[°C]) (Equation (5))
Where
Lop is the expected operating life in h,
Mv is a unitless voltage multiplier for voltage derating,
Lb is the expected operating life in h for full rated voltage
and temperature,
Tm is the maximum permitted internal operating temperature
in degC, and
Ta is the actual capacitor internal operating temperature
in degC.
However, as a capacitor heats up toward its maximum permitted
core temperature, the rules change. At temperatures above the
maximum core temperature and by 125 degC for most types the
electrolyte can be driven from capacitor element and the ESR
can increase as much as 10 times. By this mechanism, transient
over-temperature or over-current can permanently increase the
ESR and make the capacitor unusable.
