Electrolytic Capacitor as Detector or LF Noise Source
edaprojects
Newbie
The attached circuit produces a sub audio frequency, non-repetitive complex waveform. It resembles noise processed through a low pass filter.
Can anyone please tell me what exactly is being detected? In other words, the likely environmental (or other) source of the "signal" detected by the two 470uF caps and being amplified.
Looking at the scope, there is no apparent power grid artifact.
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
Some electrolytics have internal chemical action going on which generates a tiny signal.
I have taken readings of an electrolytic connected to nothing except my meter. I was surprised to see the voltage rising and falling unpredictably in a small range. My DMM was set to the 200mV range. Input resistance is 1M Ohm.
edaprojects
Newbie
So what can we attribute this to? Any way to isolate the cause?
I have used a variety of electro's in different settings. All exhibit the same type of behavior. I have found no way to influence it hands-off. But it does seem to change with capacitance value.
From my observations, I have the impression something external is being detected. Perhaps slight variations in atmospheric charge/pressure interacting with polarization of the dielectric. I am just guessing though.
It would be really interesting to find out for sure.
FvM
Super Moderator
Staff member
Bochum, Germany
It's basically a noise generator, amplifying low frequency OP noise. Different capacitor values give different gain curves.
The circuit may be influenced by thermoelectric voltages and other enviromental effects, but it's not suited as speficic detector.
edaprojects
Newbie
I assume you are referring to voltage or current op amp noise.
Any idea how the frequency spectrum of this would differ in character from reverse biased junction noise of a single transistor?
Narrower? Broader? "Tunable" with the cap? What I am thinking is that it might be an interesting alternative to explore.
Can you please identify what "other environmental effects" you refer to?
edaprojects
Newbie
Are there any further comments or advice on using an electrolytic cap as a substitute for a reversed biased transistor? In particular with regard to the spectral "quality" of the noise.
LaTeX Commands Quick-Menu:
