vamsee
Full Member level 1
I want to simulate my circuit which consists of hall sensor and its signal conditioning. Which simulation software should i use?
LTspice or Pspice or multisim?
Thanq
Thanq
It doesn`t matter at all. All software packages can do - provided they have a Hall sensor model on-board (I don`t know if there is any).I want to simulate my circuit which consists of hall sensor and its signal conditioning. Which simulation software should i use?
Thanq
yes i am building circuit with hall sensor which gives out the anologue signal and signal conditioning for it..It doesn`t matter at all. All software packages can do - provided the have a Hall sensor model on-board (I don`t know if there is any).
Or do you intend to built a model by yourself?
If you intend to simulate a circuit with a Hall sensor you need a model of this device, which can be read by the simulator.yes i am building circuit with hall sensor which gives out the anologue signal and signal conditioning for it..
what do u mean by hall sensor on-board? pls can tell that, so it might be useful for me..
thanq
The only free one on you list is LTspice, which you can download from Linear Technology and which many use on the various electronic forums.is this free software? is this possible to download online?
