tranquiltension
Junior Member level 1
Hey Everybody,
I'm using HFSS version 12 to solve for the eigenmodes of a double-dielectric material that is thought to act as a DNG metamaterial around 17 GHz. I've been searching around the Brillouin zone for my little window around 17 GHz to no avail until recently. I had to be very specific with the eigenmode solver - telling it to start looking for modes at 17 GHz.
I seem to have stumbled upon the eigenmodes that I'm intested in around 17.2 GHz, but the solver is very touchy about finding them. I'm following this guide and it's worked for other frequencies, but around 17.2 GHz, I have to lower my step size significantly to see any real behavior.
What's bothering me is that I keep getting the message like this:
So it seems to me that the eigenmode solver was unable to locate an eigenmode at px=180, py=57. When I look at my results, however, there is clearly a result at these values.
Should I trust these results? For these eigenmode runs, I'm using a mesh that was generated from a previous run that had 100% convergence. I have the solver looking for only ONE mode with REAL frequency. I have max delta frequency set at 10%, and the maximum number of passes set to 3. My minimum solution frequency is 17 GHz.
Any ideas would be helpful.
Thanks,
TT
[info] A variation (px='180deg' py='54deg') has been requested on machine Local Machine (12:34:16 AM Apr 30, 2011)
[warning] Adaptive Passes did not converge based on specified criteria. (5:44:59 PM Apr 30, 2011)
[info] A variation (px='180deg' py='57deg') has been requested on machine Local Machine (5:45:01 PM Apr 30, 2011)
[warning] PML group 'PMLGroup1' part 'PML_Air1' is contained by object 'Space' (5:45:01 PM Apr 30, 2011)
[warning] Adaptive Passes did not converge based on specified criteria. (10:11:36 AM May 01, 2011)
Thanks,
TT
