You can first set the boundary which is your need as periodic, then set the phase of the master-slave from 0-360degree, then you can sweep the parameters, after that you can get the dispersion diagram. Beta-->phase vs f.
There is a example in eigen mode. The name seems helix slow wave structure.
Good Luck
