efficient way to add increment a std_logic_vector
manasic
Junior Member level 1
Hello all;
I am writing a code for FIFO buffer and come across a stage in which I need to increment my read and write pointer. The read and write pointer are std_logic_vector. So incrementing it by 1; requires a hell lot of type cast conversion. It looks something like this:
Code VHDL - [expand]
std_logic_vector(to_unsigned(((to_integer(unsigned(weptr))) + 1),4))
I am very newbie to VHDL, can anyone suggest a better and efficient way to do this.
Thanks and regards;
Manasi.:roll:
Use the unsigned library (std_logic_unsigned). You will then be able to perform arithmetic on std_logic_vectors, e.g., a<=b+c;
In many case, you can also use either unsigned or integer (range 0 to N-1) types.
If you feel bad about using std_logic_unsigned, you can also write your own wrapper functions for "+"(x,y : std_logic_vector) and others.
At a minimum, unsigned + integer is defined, so you can do std_logic_vector(unsigned(weptr)+1).
I would use the numeric_std library and declare the pointers as "unsigned".
For hobby projects you can use any library, but as a professional you can expect that the non-standard libraries std_logic_unsigned, std_logic_arith etc. can be forbidden by some customers/employers. Therefore, if you are learning VHDL I recommend that you only use numeric_std.
I've seen both numeric_std and std_logic_unsigned used by professionals. Although not 'proper coding', std_logic_unsigned still gets used and adding directly to a std_logic_vector does look cleaner to me I have to say.
I'm a professional, and I use std_logic_unsigned. But I don't use std_logic_arith.
It depends on what the company coding guidelines are. Many companies dont really care what you do as long as it works and ships on time. But some will.
My point is that numeric_std is the safe way to go. It is a fact that std_logic_arith, std_logic_unsigned etc are forbidden in some projects/companies. I expect numeric_std to be allowed everywhere.
To the OP: it is not necessary to go all the way to integer if you really want to increment a std_logic_vector using numeric_std. It is enough to go to unsigned:
weptr <= std_logic_vector(unsigned(weptr) + 1);
Edit:
I see that this way of incrementing has already been mentioned by permute in post #3
