effective dielectric constant simulation in HFSS?
jadanz
using hfss to compute dielectric constant
Hi !
Is any possible way to show the effective dielectric constant (εeff) in HFSS?
thanks~
peiding76
Newbie level 6
If you do some work on metamaterial using HFSS, you don't get the effective dielectric constant directly. εeff can be determined from the transmission coefficient, which need retrieval procedure and is not simple.
jadanz
thx u ~ peiding76
but i just want to simulate a simple transmission line, not metamaterial type
can i just get it?
peiding76
Newbie level 6
I don't know for this case,but I suppose it should be the same as Metamaterial in HFSS simulation.
sun&moon
Newbie level 5
A simple way to get it is to simulate the transmission line structure in HFSS(larger than 1 wavelength)at the frequency interested. Then you observe the surface current distribution. You will clearly see the two nulls of one wavelength. You can measure its dimension. That will be wavelength in dilectric rg. then use the relation of rg=r0/sqrt(effitive relative dilectric constant), you will get the effective relative dilectric constant roughly.where r0 is the wavelength in air.
for simple uniform structure, you can use APPCAD to directly get it.
pareshatlnmiit
Member level 1
there is a method of finding Z0(impedance) and impedance always related to effective dielectric constant so find Z0 nad look for equations then eff. dilelectric constant
kimx0945
Newbie level 3
A simple way to calculate the effective dielectric constant of a transmission line is to use the unwrapped phse of the S21. The phase of S21 is electrical length of the transmission line in degree. So, you can plot the effective dielectric constant versus frequencies by adding an expression of the output variable as shown below.
θ=(2*pi/λ)*L where L=physical length of the transmission line, θ=unwrapped phase of S21.
=(2*pi*√(er_eff)/λ0)*L
Er_eff=(θ*c/(2*pi*f*L))^2;
Actually, the expression for the effective dielectric consatnt is more complex, but for general transmission lines such as microstrip lines and CPWs, you can use this express.
