eeprom(serial or parallel) or NVRAM
fortunesoldier
Newbie level 1
Europe
Hi all,
I am designing an microcontroller board in which I need a memory array for storing some parameters, which I analyse later, after I download them towards to the PC. The memory dimension or lenght of the buffer should be somewhere around 400kbytes. The other significant factor which I have to take into account is the data integrity(noise, spikes harsh conditions). The speed is not so important because I take the parameters every 5 minutes. So, is it better to use a couple of huge 24Cxx eeproms or maybe a parallel variant of the eeproms, or I could use the NVRam chips from Dallas or similar? Or maybe a flash chip. My microcontroller is an 8051 type, so if someone can recomend me the simplest and the most appropriate solution for this problem.
penrico
Full Member level 5
Argentina
See Atmel and Microchip, web pages, they have serial flash eproms with 512Kx8 bytes and more!!!!
8O
smanish
Member level 1
FLASH is better here
I feel Flash is a better solution for your requirement. Mainly NVRAM is used to keep/store the crash/history/debug data. It is a costly solution too. Flash is cheap, popular and easily available in all the ranges/capacity. Programming/reprogramming is far better than any EEPROM available. Now a days FLASH is available with combined NAND and NOR technology, so same can be used for boot code and application CODE.
ms
smanish
Member level 1
AMD, FUJITSU,ST Microelectronics web sites will be having more info on it..
ms
