inevitablewish
Newbie level 5
EDK ERROR:MDT - Error while running "generate" for microblaze...../ please help
please help me ... i find following errors. help me to solve the highlighted error i will be grateful/
Creating software libraries...
libgen -mhs system.mhs -p xc4vfx12ff668-10 system.mss
libgen
Xilinx EDK 9.1 Build EDK_J.19
Copyright (c) 1995-2007 Xilinx, Inc. All rights reserved.
Command Line: libgen -mhs system.mhs -p xc4vfx12ff668-10 system.mss
Output Directory (-od) : C:\Documents and Settings\Mohsin\My Documents\lab2\
Part (-p) : virtex4
Software Specification file : system.mss
Sourcing tcl file
C:/EDK/hw/XilinxProcessorIPLib/pcores/microblaze_v6_00_a/data/microblaze_v2_1_0.
tcl ...
Sourcing tcl file
C:/EDK/hw/XilinxProcessorIPLib/pcores/opb_mdm_v2_00_a/data/opb_mdm_v2_1_0.tcl
Sourcing tcl file
C:/EDK/hw/XilinxProcessorIPLib/pcores/lmb_v10_v1_00_a/data/lmb_v10_v2_1_0.tcl
Sourcing tcl file
C:/EDK/hw/XilinxProcessorIPLib/pcores/lmb_bram_if_cntlr_v2_00_a/data/lmb_bram_if
_cntlr_v2_1_0.tcl ...
Sourcing tcl file
C:/EDK/hw/XilinxProcessorIPLib/pcores/dcm_module_v1_00_a/data/dcm_module_v2_1_0.
tcl ...
Overriding IP level properties ...
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\microblaze_v6_00_a\data\microblaze_v2_1
_0.mpd line 68 - microblaze_0 (microblaze) tool is overriding PARAMETER
C_FAMILY value to virtex4
INFO:MDT -
_0.mpd line 69 - microblaze_0 (microblaze) tool is overriding PARAMETER
C_INSTANCE value to microblaze_0
INFO:MDT -
_0.mpd line 104 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_ADDR_TAG_BITS value to 0
INFO:MDT -
_0.mpd line 112 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_DCACHE_ADDR_TAG value to 0
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\opb_mdm_v2_00_a\data\opb_mdm_v2_1_0.mpd
line 41 - debug_module (opb_mdm) tool is overriding PARAMETER C_FAMILY value
to virtex4
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\bram_block_v1_00_a\data\bram_block_v2_1
_0.mpd line 41 - lmb_bram (bram_block) tool is overriding PARAMETER C_FAMILY
value to virtex4
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\opb_gpio_v3_01_b\data\opb_gpio_v2_1_0.m
pd line 40 - LEDs_4Bit (opb_gpio) tool is overriding PARAMETER C_FAMILY value
to virtex4
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\dcm_module_v1_00_a\data\dcm_module_v2_1
_0.mpd line 59 - dcm_0 (dcm_module) tool is overriding PARAMETER C_FAMILY
value to virtex4
INFO:MDT -
pd line 40 - Push_Button_5bBit (opb_gpio) tool is overriding PARAMETER
Performing IP level DRCs on properties...
Running DRC Tcl procedures for OPTION IPLEVEL_DRC_PROC...
Address Map for Processor microblaze_0
(0000000000-0x00001fff) dlmb_cntlr dlmb
(0000000000-0x00001fff) ilmb_cntlr ilmb
(0x40000000-0x4000ffff) LEDs_4Bit mb_opb
(0x40020000-0x4002ffff) Push_Button_5bBit mb_opb
(0x40600000-0x4060ffff) RS232_Uart mb_opb
(0x41400000-0x4140ffff) debug_module mb_opb
Check platform address map ...
Overriding system level properties ...
INFO:MDT -
_0.mpd line 71 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_D_OPB value to 1
INFO:MDT -
_0.mpd line 72 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_D_LMB value to 1
INFO:MDT -
_0.mpd line 73 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_I_OPB value to 1
INFO:MDT -
_0.mpd line 74 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_I_LMB value to 1
INFO:MDT -
_0.mpd line 94 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_INTERRUPT_IS_EDGE value to 0
INFO:MDT -
_0.mpd line 95 - microblaze_0 (microblaze) tcl is overriding PARAMETER
C_EDGE_IS_POSITIVE value to 1
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\opb_v20_v1_10_c\data\opb_v20_v2_1_0.mpd
line 36 - mb_opb (opb_v20) tool is overriding PARAMETER C_OPB_AWIDTH value to
32
INFO:MDT -
line 37 - mb_opb (opb_v20) tool is overriding PARAMETER C_OPB_DWIDTH value to
32
INFO:MDT -
line 38 - mb_opb (opb_v20) tool is overriding PARAMETER C_NUM_MASTERS value
to 2
INFO:MDT -
line 39 - mb_opb (opb_v20) tool is overriding PARAMETER C_NUM_SLAVES value to
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\lmb_v10_v1_00_a\data\lmb_v10_v2_1_0.mpd
line 38 - ilmb (lmb_v10) tool is overriding PARAMETER C_LMB_NUM_SLAVES value
to 1
INFO:MDT -
line 39 - ilmb (lmb_v10) tool is overriding PARAMETER C_LMB_AWIDTH value to
32
INFO:MDT -
line 40 - ilmb (lmb_v10) tool is overriding PARAMETER C_LMB_DWIDTH value to
32
INFO:MDT -
line 38 - dlmb (lmb_v10) tool is overriding PARAMETER C_LMB_NUM_SLAVES value
to 1
INFO:MDT -
line 39 - dlmb (lmb_v10) tool is overriding PARAMETER C_LMB_AWIDTH value to
32
INFO:MDT -
line 40 - dlmb (lmb_v10) tool is overriding PARAMETER C_LMB_DWIDTH value to
32
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\lmb_bram_if_cntlr_v2_00_a\data\lmb_bram
_if_cntlr_v2_1_0.mpd line 44 - dlmb_cntlr (lmb_bram_if_cntlr) tool is
overriding PARAMETER C_MASK value to 0x40000000
INFO:MDT -
_if_cntlr_v2_1_0.mpd line 45 - dlmb_cntlr (lmb_bram_if_cntlr) tool is
overriding PARAMETER C_LMB_AWIDTH value to 32
INFO:MDT -
_if_cntlr_v2_1_0.mpd line 46 - dlmb_cntlr (lmb_bram_if_cntlr) tool is
overriding PARAMETER C_LMB_DWIDTH value to 32
INFO:MDT -
_if_cntlr_v2_1_0.mpd line 44 - ilmb_cntlr (lmb_bram_if_cntlr) tool is
INFO:MDT -
_if_cntlr_v2_1_0.mpd line 45 - ilmb_cntlr (lmb_bram_if_cntlr) tool is
INFO:MDT -
_if_cntlr_v2_1_0.mpd line 46 - ilmb_cntlr (lmb_bram_if_cntlr) tool is
INFO:MDT -
_0.mpd line 37 - lmb_bram (bram_block) tool is overriding PARAMETER C_MEMSIZE
value to 0x2000
INFO:MDT -
_0.mpd line 38 - lmb_bram (bram_block) tool is overriding PARAMETER
C_PORT_DWIDTH value to 32
INFO:MDT -
_0.mpd line 39 - lmb_bram (bram_block) tool is overriding PARAMETER
C_PORT_AWIDTH value to 32
INFO:MDT -
_0.mpd line 40 - lmb_bram (bram_block) tool is overriding PARAMETER C_NUM_WE
value to 4
INFO:MDT -
C:\EDK\hw\XilinxProcessorIPLib\pcores\opb_uartlite_v1_00_b\data\opb_uartlite_
v2_1_0.mpd line 37 - RS232_Uart (opb_uartlite) tool is overriding PARAMETER
C_OPB_DWIDTH value to 32
INFO:MDT -
v2_1_0.mpd line 38 - RS232_Uart (opb_uartlite) tool is overriding PARAMETER
C_OPB_AWIDTH value to 32
INFO:MDT -
pd line 38 - LEDs_4Bit (opb_gpio) tool is overriding PARAMETER C_OPB_AWIDTH
value to 32
INFO:MDT -
pd line 39 - LEDs_4Bit (opb_gpio) tool is overriding PARAMETER C_OPB_DWIDTH
value to 32
INFO:MDT -
pd line 38 - Push_Button_5bBit (opb_gpio) tool is overriding PARAMETER
INFO:MDT -
pd line 39 - Push_Button_5bBit (opb_gpio) tool is overriding PARAMETER
Running system level Update ...
Running UPDATE Tcl procedures for OPTION SYSLEVEL_UPDATE_PROC...
Performing System level DRCs on properties...
Running DRC Tcl procedures for OPTION SYSLEVEL_DRC_PROC...
Check platform configuration ...
IPNAMEpb_v20 INSTANCE:mb_opb - C:\Documents and Settings\Mohsin\My
Documents\lab2\system.mhs line 45 - 2 master(s) : 4 slave(s)
IPNAME:lmb_v10 INSTANCE:ilmb - C:\Documents and Settings\Mohsin\My
Documents\lab2\system.mhs line 70 - 1 master(s) : 1 slave(s)
IPNAME:lmb_v10 INSTANCE:dlmb - C:\Documents and Settings\Mohsin\My
Documents\lab2\system.mhs line 78 - 1 master(s) : 1 slave(s)
Check port drivers...
WARNING:MDT - INST:dcm_0 PORT:LOCKED CONNECTOR:dcm_0_lock - C:\Documents and
Settings\Mohsin\My Documents\lab2\system.mhs line 151 - floating connection!
Performing Clock DRCs...
INFO:MDT - List of peripherals addressable from processor instance microblaze_0
- dlmb_cntlr
- ilmb_cntlr
- mb_opb
WARNING:MDT - C:\Documents and Settings\Mohsin\My Documents\lab2\system.mhs line
45 - No Driver Found for instance mb_opb. To avoid seeing this warning,
assign the appropriate driver or driver "generic 1.00.a " to instance mb_opb
- debug_module
- RS232_Uart
- LEDs_4Bit
- Push_Button_5bBit
Building Directory Structure for microblaze_0
Generating platform libraries and device drivers ...
Running CopyFiles ...
Copying files for os standalone_v1_00_a from
C:\EDK\sw\lib\bsp\standalone_v1_00_a\src\ to C:\Documents and Settings\Mohsin\My
Documents\lab2\microblaze_0\libsrc\standalone_v1_00_a\ ...
cp: copying multiple files, but last argument `Documents/lab2/microblaze_0/libsrc/standalone_v1_00_a/' is not a directory
Try `cp --help' for more information.
cp: copying multiple files, but last argument `Documents/lab2/microblaze_0/libsrc/common_v1_00_a/' is not a directory
Copying files for driver uartlite_v1_01_a from
C:\EDK\sw\XilinxProcessorIPLib\drivers\uartlite_v1_01_a\src\ to C:\Documents and
Settings\Mohsin\My Documents\lab2\microblaze_0\libsrc\uartlite_v1_01_a\ ...
cp: copying multiple files, but last argument `Documents/lab2/microblaze_0/libsrc/uartlite_v1_01_a/' is not a directory
Copying files for driver gpio_v2_01_a from
C:\EDK\sw\XilinxProcessorIPLib\drivers\gpio_v2_01_a\src\ to C:\Documents and
Settings\Mohsin\My Documents\lab2\microblaze_0\libsrc\gpio_v2_01_a\ ...
cp: copying multiple files, but last argument `Documents/lab2/microblaze_0/libsrc/ipif_v1_23_b/' is not a directory
cp: copying multiple files, but last argument `Documents/lab2/microblaze_0/libsrc/gpio_v2_01_a/' is not a directory
Copying files for driver cpu_v1_01_a from
C:\EDK\sw\XilinxProcessorIPLib\drivers\cpu_v1_01_a\src\ to C:\Documents and
Settings\Mohsin\My Documents\lab2\microblaze_0\libsrc\cpu_v1_01_a\ ...
cp: copying multiple files, but last argument `Documents/lab2/microblaze_0/libsrc/cpu_v1_01_a/' is not a directory
Running DRCs for OSes, Drivers and Libraries ...
Running generate for OS'es, Drivers and Libraries ...
ERROR:MDT - standalone () - couldn't open "./src/config.make": no such file or
directory
while executing
"open "./src/config.make" w"
(procedure "::sw_standalone_v1_00_a::generate" line 44)
invoked from within
"::sw_standalone_v1_00_a::generate 37586504"
ERROR:MDT - uartlite () - couldn't open "src/xuartlite_g.c": no such file or
directory
while executing
"open $filename w"
(procedure "xdefine_config_file" line 4)
invoked from within
"xdefine_config_file $drv_handle "xuartlite_g.c" "XUartLite" "DEVICE_ID"
"C_BASEADDR" "C_BAUDRATE" "C_USE_PARITY" "C_ODD_PARITY" "C_DATA_BITS""
(procedure "::sw_uartlite_v1_01_a::generate" line 3)
invoked from within
"::sw_uartlite_v1_01_a::generate 38051284"
ERROR:MDT - gpio () - couldn't open "src/xgpio_g.c": no such file or directory
while executing
"open $filename w"
invoked from within
"xdefine_config_file $drv_handle "xgpio_g.c" "XGpio" "DEVICE_ID"
"C_BASEADDR" "C_INTERRUPT_PRESENT" "C_IS_DUAL""
(procedure "::sw_gpio_v2_01_a::generate" line 4)
invoked from within
"::sw_gpio_v2_01_a::generate 38011160"
Copying Library Files ...
ERROR:MDT - Error while running "generate" for processor microblaze_0...
make: *** [microblaze_0/lib/libxil.a] Error 2
Done!
libgen
Part (-p) : virtex4
Sourcing tcl file
tcl ...
Sourcing tcl file
Sourcing tcl file
Sourcing tcl file
Sourcing tcl file
tcl ...
INFO:MDT -
INFO:MDT -
INFO:MDT -
INFO:MDT -
INFO:MDT -
to virtex4
INFO:MDT -
value to virtex4
INFO:MDT -
to virtex4
INFO:MDT -
value to virtex4
INFO:MDT -
INFO:MDT -
C_D_OPB value to 1
INFO:MDT -
C_D_LMB value to 1
INFO:MDT -
C_I_OPB value to 1
INFO:MDT -
C_I_LMB value to 1
INFO:MDT -
INFO:MDT -
INFO:MDT -
32
INFO:MDT -
32
INFO:MDT -
to 2
INFO:MDT -
INFO:MDT -
to 1
INFO:MDT -
32
INFO:MDT -
32
INFO:MDT -
to 1
INFO:MDT -
32
INFO:MDT -
32
INFO:MDT -
INFO:MDT -
INFO:MDT -
INFO:MDT -
INFO:MDT -
INFO:MDT -
INFO:MDT -
value to 0x2000
INFO:MDT -
INFO:MDT -
INFO:MDT -
value to 4
INFO:MDT -
INFO:MDT -
INFO:MDT -
value to 32
INFO:MDT -
value to 32
INFO:MDT -
INFO:MDT -
- dlmb_cntlr
- ilmb_cntlr
- mb_opb
- debug_module
- RS232_Uart
- LEDs_4Bit
- Push_Button_5bBit
directory
while executing
invoked from within
directory
while executing
"open $filename w"
invoked from within
invoked from within
while executing
"open $filename w"
invoked from within
invoked from within
Done!
