Nov 26, 2016 #1 D deniz88 Member level 2 Joined Jul 28, 2009 Messages 47 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location germany Activity points 1,703 Hi, something confuses me about Linker settings of Eclipse. When i need to use thread or opencv, i have to add library in linker. As i know, linker converts the object (*.o) files to executable file. Why does it require .h or .c files if it works with .o files. thank you best regards
Dec 9, 2016 #2 D deniz88 Member level 2 Joined Jul 28, 2009 Messages 47 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Location germany Activity points 1,703 anyone knows about it?
Dec 9, 2016 #3 S srizbf Advanced Member level 5 Joined Apr 3, 2010 Messages 1,992 Helped 417 Reputation 840 Reaction score 329 Trophy points 1,363 Activity points 10,985 A linker do not require .h and .c files. Are you referring the settings as a whole or linker alone? If using gcc , better use the command line or makefile approach. Saves lot of headaches in settings.
