flash test is 3500vac for one minute.
as the OP says, the battery is obviously isolated from earth ground,
What about a battery on a plane?....you see what I mean....if a battery rail is not connected to earth, then its voltage is not referenced to earth.Obviously this cannot be correct because all potentials are always defined with respect to the earth.
