dannym
Newbie level 6
I created Gerber files as per the instructions at:
https://www.hobby-elec.org/e_eagle44.htm
I opened them up in Viewmate. I am unfamiliar with this tool and manually used "Import" on each file to display the layers on top of each other.
The bottom layers are flipped horizontally. Is this just a display problem or will the manufacturer create a useless board in the same way?
If this is a display problem, how can I view it where the bottom layers can be superimposed with the same orientation?
