Eagle Pro...copper pour not "filling in"
T
treez
Newbie level 1
Hello,
I've just put a polygon on the bottom layer and named it to the "drain" net........i have put thermal vias in it.....but it won't fill in....its just an outline.....how do i fill the copper pour?
You need to to set the option 'ratsnest processes polygons' (or something similar) in the setup menu. Then do a RATSNEST command.
Keith
Reactions: treez
    T
Chose Polygoon Tool> Before drawing Polygon Tool Set Your Isolation in the top toolbar option as 40mills or whatever your requirement is then draw the Polygon after it turned to dotter chose name toolbar and click on the polygon and set name to GND then click the ratsnet button and see the magic! you can also change the isolation setting after its been pour by using info tool and click on the side of polygon tool!
Isolation is the setting you want to give to tell that how much distance will be between your ground pour and routing layers!
Regards,
Punit
assuming you have created the polygon properly, you should see the pour as soon as you click on ratsnest icon
Oh yes - also when you name it, be sure to select "Entire Signal"
Reactions: treez
    T
