Are you sure you have re-run the ERC since editing the schematic?
Keith.
Are you using the latest version?
Hi all, i saw the problem is solved, but i wish to tell to others, who may have the same trouble in the future. So, the reason is grid settings, when you choose component from library and put it on the sheet and then change grid parameters, the program not be able to connect properly components each other. That's all! I hope this info will help somebody.
