Altium Designer can import Orcad PCB (.MAX), PADS ASCII PCB (.ASC), and PCAD PCB (.PCB). If you can get your design into one of those formats, you can do a direct import.
An alternative would be to output Gerber, drill, and IPC-D-356A from Eagle. You could then reverse engineer the board into Altium Designer from the CAMTASTIC Editor. There is a PDF document in the help files installed with Altium Designer that describes how to reverse engineer.
