david90
Advanced Member level 1
I keep on getting Dimension Error whenever I do a DRC. The errors are located at the pads of my thru hole connector.
From my understanding, a dimension error occurs because a trace is too close to a dimension layer. The pads for my through hole connector has a dimension layer added by eagle automatically when I add a drill hole. Why does eagle do this? If there's a dimension layer in the middle of my pad, then how can I connect a trace to the pad without getting a dimension error???
Please see screenshot below.
