dainis
New low cost (10 USD for 1K) Fast Ethernet switch (bridge with Wan HDLC link) AT8993
Orcad Schematics
The AT8993 is an integrated (Controller, PHY and Memory) two 10/100 Mbps MDIX TX/FX transceiver, three 10/100 MAC Ethernet L2 switch controller, built-in 5 counters on each MAC read through serial management I/O pins, targeted at stand alone bridge for low cost SOHO market, Media Converter.
The 3rd MAC interface could be selected as MII/RMII/GPSI/HDLC to connect with routing devices, bridge devices for different media.
Features
3 port 10/100M integrated switch with interfaces of two MDIX TX/FX and 3rd port as GPSI/MII/RMII/HDLC
Built-in data buffer 6Kx64 SRAM
Up to 2048 MAC unicast addresses with 4-layer hashing table
Two queues / port for QoS purpose
Port-base, 802.1p and IP ToS priority
Store & forward architecture and Performs forwarding and filtering at non-blocking full wire speed
Supports aging function
Supports 802.3x flow control for full duplex and back-pressure for half duplex in case buffer is full
Support packet length up to 1536 bytes
Support Broadcast storm filter
Support port-base VLAN
Tag/Untagged function on each MAC.
Support five Smart counters on each MAC.
Support 16 entry of packet classify and marking or filtering for TCP port number
Provide TX1FX Converter mode with fault propagation and redundant capability by use of two AT8993.
Short latency on the converter mode.
100 PQFP package with 2.5V/3.3V power supply
Orcad Schematics
Features
