preethi19
Full Member level 5
Hi i am learning the basics of ADC. I understand the concept of resolution, samples and all. But how can i determine the Input frequency range that the ADC can function.
i found this online "I bought a Analog to Digital Converter but did not gave much attention to Dynamic range. The resolution is 12 Bit. Minimum input voltage is 0V and maximum is 5V. Additional info: It says it has 10Megasample per sec of sample-rate."
So i have details of the min and max input voltage range, resolution and sample rate too. How can i determine the frequency range. To know what is the lowest and highest frequency range i can have my input signal.
I found the above mentioned ADC details on this site https://electronics.stackexchange.com/questions/120590/how-to-find-the-dynamic-range-of-adc
Here they have calculated the dynamic range to be 72dB. But why dB. I thought dynamic range is the range of input values the ADC can take which is either range of input amplitude voltage (V) or input frequency range (in Hz). What does 72dB mean here. I read dB represents intensity which is amplitude. But then we have the max amplitude range that the input can go is 5V. Additionally how did they arrive at 72dB. 5/0.0012 gives 4098. I'm little confused here. Can anyone pls explain in simple terms. Thank you!!!
