Dynamic Element Matching and Noise Shaping
mike_bihan
Full Member level 3
dynamic element matching dac
There are quite a few papers stated that they could shape the mismatch noise in DAC, by using special scrambling techniques.
However, I very much doubt it, since the error of DAC will not be sensed by circuit, it is impossible to shape it as sigma-delta modulator do. The best way of noise reduction is to randomly select elements and make the mismatch looks as white noise, and was pushed to high frequency range.
Believe it or not, there are much better ways to do dynamic matching. Some of them are described in papers. Another part - in patents.
noise shaping dynamic element matching
Is there any way to briefly explain it?
I've read a few papers, they don't make sense to me though.
randomly select elements is one method of DEM.
it's the noise shaping indeed.
In This paper a new method is introduced instead of using DEM.
The attachment is gone. Can you give the full name of this paper?
in the data converter book, chapter 7 you can find a description of several techniques for dem.
Hi mike_bihan,
The paper is :
"A Low-Power Multi-Bit delta sigma Modulator in 90-nm Digital CMOS Without DEM"
Jiang Yu and Franco Maloberti, Journal of Solid State Circuits, 2005.
