HI DEAR,
The dynamical system concept is a mathematical formalization for any fixed "rule" which describes the time dependence of a point's position in its ambient space. The mathematical models used to describe the swinging of a clock pendulum, the flow of water in a pipe, or the number of fish each spring in a lake are examples of dynamical systems.
A dynamical system has a state determined by a collection of real numbers, or more generally by a set of points in an appropriate state space. Small changes in the state of the system correspond to small changes in the numbers. The numbers are also the coordinates of a geometrical space—a manifold. The evolution rule of the dynamical system is a fixed rule that describes what future states follow from the current state. The rule is deterministic: for a given time interval only one future state follows from the current state.
Basic definitions
A dynamical system is a manifold M called the phase (or state) space and a smooth evolution function Φ t that for any element of t ∈ T, the time, maps a point of the phase space back into the phase space. The notion of smoothness changes with applications and the type of manifold. There are several choices for the set T. When T is taken to be the reals, the dynamical system is called a flow; and if T is restricted to the non-negative reals, then the dynamical system is a semi-flow. When T is taken to be the integers, it is a cascade or a map; and the restriction to the non-negative integers is a semi-cascade.
The evolution function Φ t is often the solution of a differential equation of motion
The equation gives the time derivative, represented by the dot, of a trajectory x(t) on the phase space starting at some point x0. The vector field v(x) is a smooth function that at every point of the phase space M provides the velocity vector of the dynamical system at that point. (These vectors are not vectors in the phase space M, but in the tangent space TMx of the point x.) Given a smooth Φ t, an autonomous vector field can be derived from it.
There is no need for higher order derivatives in the equation, nor for time dependence in v(x) because these can be eliminated by considering systems of higher dimensions. Other types of differential equations can be used to define the evolution rule:
is an example of an equation that arises from the modeling of mechanical systems with complicated constraints.
The differential equations determining the evolution function Φ t are often ordinary differential equations: in this case the phase space M is a finite dimensional manifold. Many of the concepts in dynamical systems can be extended to infinite-dimensional manifolds—those that are locally Banach spaces—in which case the differential equations are partial differential equations. In the late 20th century the dynamical system perspective to partial differential equations started gaining popularity
Statics is the branch of physics concerned with the analysis of loads (force, moment, torque) on a physical systems in static equilibrium, that is, in a state where the relative positions of subsystems do not vary over time, or where components and structures are at rest under the action of external forces of equilibrium. When in static equilibrium, the system is either at rest, or moving at constant velocity through its center of mass.
By Newton's second law, this situation implies that the net force and net torque (also known as moment) on every body in the system is zero, meaning that for every force bearing upon a member, there must be an equal and opposite force. From this constraint, such quantities as stress or pressure can be derived. The net forces equalling zero is known as the first condition for equilibrium, and the net torque equalling zero is known as the second condition for equilibrium. See statically determinate.
Statics is thoroughly used in the analysis of structures, for instance in architectural and structural engineering. Strength of materials is a related field of mechanics that relies heavily on the application of static equilibrium.
Hydrostatics, also known as fluid statics, is the study of fluids at rest. This analyzes systems in static equilibrium which involve forces due to mechanical fluids. The characteristic of any fluid at rest is when a force is exerted on any particle of the fluid is the same in any direction. If the force is unequal the fluid will move in the direction of the resulting force. This concept was first formulated in a slightly extended form by the French mathematician and philosopher Blaise Pascal in 1647 and would be later known as Pascal's Law. This law has many important applications in hydraulics. Galileo also was a major figure in the development of hydrostatics.
In economics, "static" analysis has substantially the same meaning as in physics. Since the time of Paul Samuelson's Foundations of Economic Analysis (1947), the focus has been on "comparative statics", i.e., the comparison of one static equilibrium to another, with little or no discussion of the process of going between them – except to note the exogenous changes that caused the movement
Electrostatics is the branch of physics that deals with the forces exerted by a static (i.e. unchanging) electric field upon charged objects
